Hi All
I have a 2008 XC90 3.2 AWD. Recently the CEL came on and i scanned it with my OBD and it showed p2421. I cleared it and 3 days later it came back on. I can't figure out which valve is stuck open. Purge valve? Leak detection pump? or is it something simple like a software update or Fuel cap. Car runs normal. I even had it hooked up to a Vida Clone and the code showed PCM 242100. The screen for both scanners reads "Evap emission system vent valve stuck open" Any ideas would be great. I tried unplugging the purge valve and it threw a different code. Unplugged the leak detection pump and it threw a different code. Only code that remains after resetting and waiting for it to come back on is the 2421. Thanks in advance for your help..
2008 XC90 3.2. CEL ON P2421. What could it be?
mchannell5
- Year and Model: 2012
Just curious if you ever found out what the fix was? Seem to be having the same issue on my 2012, and I’m trying to figure it out.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
It looks like this code is set if the leak detection detects a vacuum with the purge valve in the closed position.
Options
1. Disconnect the electrical connection from the purge valve reset the code and see if it comes back
2. Thump the purge valve
3. Clamp the hose between the valve and the intake manifold
The Valve (Hose to manifold is visible, electrical harness disconnected, purge line from fuel tank disconnected)
The Valve is the on the top left side of the picture.
The Manifold
I included this picture of the intake manifold to make it easier to find the valve
Good luck
Paul
Options
The Manifold
Good luck
Paul
- 2238 Views
Last post by jodisxc90
- 10210 Views
Last post by FREEBUSINESSES
- 2810 Views
Last post by eapowers64
- 1359 Views
Last post by chitownV
- 2084 Views
Last post by cuhfs
