2007 S40 coolant leak
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Post by Craigd2599 »
Okay so I got the head gasket replaced, new head bolts, everything done. To be honest...it wasn't as hard a job as I thought it would be. I got it all back together and last night as i was filling the expansion tank, I noticed that the coolant was running out almost as soon as I was putting it in. It was coming from the center, rear of the engine. I can't tell if that is the source of the leak or if it's just looking that way because of the skid plate and that's just where the fluid escapes from. Is there a coolant hose or port back there? I thought maybe the water pump bypass was the culprit because the car is cold and hasn't been started yet. Wouldn't the coolant stop at the thermostat until the car reaches operating temp?
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
Use a low pressure coolant system tester. Put low pressure around 2-3 then 4-5 lbs of pressure (do not go above 10) in the coolant tank and you will find the leak. They have loaners at Advanced Auto and other parts stores. Go low and slow. Thats what I did after my head replacement . Found the leak at the t-stat housing.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Craigd2599
funny...that's where my problems began. The thermostat stuck shut, causing the overheating, and in the process it cracked the housing. I replaced the housing during the head gasket replacement but this leak has yet to be found. I'm thinking it's the o-ring on the metal coolant pipe in the rear of the car.
Craig D
