there is a small bayonet type light that goes into the antenna ring, at least i think that is the antenna ring. the module that is around the ignition lock cylinder.
anyway, that little light is burned out and i can't seem to find a replacement. any help on the name of that light and a source is appreciated. i've searched tasca, fcp, ipd, ebay with no luck.
2005 xc70 antenna/light ring
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
donc
- Year and Model: 2006 V70 2.5T Wagon
I found the bulb for a 2006 V70. I think it will work for you or at least point you in the right direction!
http://www.volvopartswebstore.com/showA ... lYear=2006
Good luck!
Good luck!
2006 V70 2.5T Wagon
1997 850 GLT Wagon
1997 850 GLT Wagon
mrscullini
that's the one, thanks so much.donc wrote:I found the bulb for a 2006 V70. I think it will work for you or at least point you in the right direction!
Good luck!
bfry
- Year and Model: 2006 XC90 2.5T AWD
- Has thanked: 31 times
Reviving an old topic...trying to replace the same bulb in a 2006 XC90 - can someone tell me how to access it or point me in the right direction? Have had no luck searching google or YouTube - thx
- 6343 Views
Last post by Blacklab467
- 929 Views
- 11 Replies
- 2160 Views
- 2933 Views
Last post by mika
- 617 Views
Last post by MarcM
