06 XC70 Where are the marks for cam gears?
Crumpler
Year and Model: XC70 2006
Has thanked: 2 times
Post by Crumpler »
Hey guys, I'm just getting started on a TB replacement.
Car is running fine but maintenance job.
I can't find any marks, of any kind, on the cam gears to match to the notches on the TB cover???
Did the factory mark them on assembly?
There are symbols on the tabs of the gears, initially I was looking at the ".." mark, but they would never match up. I've cranked it around several times. How do I find TDC?
I'm confused, so I have not pulled old belt off yet.
Any help is appreciated and thanks ahead of time
Dave
2006 XC70
132,000 miles
Crumpler
Post by Crumpler »
Ok, I got out my electron microscope and found the timing marks on cam gears and crank.
In my 928, I had a flywheel lock to get the pulley off the crank. In the walkthrough I have for the Volvo, nobody is mentioning the need for that. How do you get the four 10mm and 30 mm loose without rotating the crank?
Dave
2006 XC70
132,000 miles
mrscullini
Year and Model: 05 XC70, 08 XC70
Has thanked: 1 time
Post by mrscullini »
Crumpler wrote:Ok, I got out my electron microscope and found the timing marks on cam gears and crank.
i used a pneumatic impact driver.
i haven't done the t-belt on my '05, however, you may be able to remove the belt without removing the crank pulley. i'm not a big fan of this, more because of possible damage to the new belt during installation.
Crumpler
Post by Crumpler »
mrscullini, thanks for the insight man. For some reason I thought this would be easier then the Porsche, shame on me, lol.
I just got everything off with the impact driver, had to soak that 30 for awhile with PB blaster, it was a bear.
If possible, can you keep me on your radar screen, as a rookie I might get myself in trouble again.
Regards, Dave.
Dave
2006 XC70
132,000 miles
zanzabar
Year and Model: '07 V70, '84 245
Has thanked: 1 time
Been thanked: 4 times
Post by zanzabar »
Dave, I just went through the same. That 30mm nut on the crank pulley was a doozy! I threaded two of the four small pulley bolts through a long gear tool to keep the crank from turning and then needed about 5' of breaker bar and all my strength to bust it loose.
Note to self: get impact wrench someday.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
Crumpler
Post by Crumpler »
zanzabar wrote:Dave, I just went through the same. That 30mm nut on the crank pulley was a doozy! I threaded two of the four small pulley bolts through a long gear tool to keep the crank from turning and then needed about 5' of breaker bar and all my strength to bust it loose.
Ok Z, that was a clever idea I must say. I was looking at mine today for about 20 min trying to come up with a plan. At one point I was going to fabricate a plate to bolt in two of the four 10 mm holes and then crank around until it jammed on the lower suspension arm with my 8 ft cheater. Then the PB blaster apparently kicked in and saved me from myself...
Yeah, I was ready to rock and roll and then noticed that I had the wrong tensioner in my FCP kit :cry:
Was 2006 a split production year?
I guess I will try and score the right one at the dealer this weekend.
Regards.
Dave
2006 XC70
132,000 miles
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If your engine is a 2.5 five cylinder you shouldn't have to remove the the crank damper pulley. Just remove the plastic dust cover from the bottom side right behind the pulley. Two 10mm bolts as I recall.
Crumpler
Post by Crumpler »
:oops:
Ugh, I didn't even entertain that as an option.
Sigh. that makes sense doesn't it.
Dave
2006 XC70
132,000 miles
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Like this guy (he does it real quick because it's probably not his first)
Crumpler
Post by Crumpler »
You guys, this is a different question buried in this thread but I have belt on and marks look good.
Specifically I'm confused about setting the tensioner.
By my guide the center screw set finger tight, then using allen head rotate tensioner face clock wise until arm positioned in middle of the bracket. Then tighten center screw.
He's my issue: tension looks good but allen hole is at eight o'clock.
The guide made it sound as if the position of the allen hole is important and they said six oclock.
In my pics of the old tensioner, before I broke everything down, it is positioned at one oclock.
How much does this matter? Tension feels good and engine turns fine.
About eighty degrees in garage.
Dave
2006 XC70
132,000 miles
