1994 940 Engine won't turn over after replacing timing belt
correllkp
Year and Model: 1995 850, 1996 960
Been thanked: 3 times
Post by correllkp »
Water pump was leaking at top of pump so decided to change pump and timing belt while I was at it. A little background. My son was driving the car and said it started to smell funny...said the temp gauge looked normal. By time he got home I noticed the pump was leaking but I think he got home before the engine overheated. So, changed the pump, the seals, the crankshaft pulley, the tensioner, the timing belt. Everything seemed to align correctly. Put it all back together. Pump still leaks, don't even have to turn car on, just start to fill up the fluid and it starts to leak from the top of the pump (like it did before). Engine won't turn over, almost like there is no spark but can smell gas. I think for the pump I will need to use gasket material but not sure why the car won't even try to turn over. Any thoughts would be appreciated.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
correllkp wrote:Engine won't turn over, almost like there is no spark but can smell gas..
Well, if engine did not turn at all, then you have a leaking injector.
If engine is locked up, and timing belt was installed incorrectly, then someone may have saved the head too much.
Everything your need to know about: Engine: Seals, Belts, Crankcase Ventilation
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
When I first did a timing belt on my 240, it took 3 iterations/placements to get the engine in proper "TDC". A great preflight test is to manually turn it over a couple revolutions, and inspect to make sure all timing marks still line up.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
correllkp
Post by correllkp »
Update. Turns out that for some reason the cam gear had two opposite white marks...I of course selected the wrong white mark when putting everything back together. Looking closer you can see a dimple in the gear...using that as the alignment mark the engine started after putting everything back together.
93Regina
Post by 93Regina »
correllkp wrote:Update....Looking closer you can see a dimple in the gear
FWIW
