The speedometer works but the odometer both trip and acual milage do not work. I got the oil changed at the dealer last week and they said it will cost around 100 dollars to fix.
Also I had a check engine light. They looked into the light and it was error code 411 Throttle sensor.
Is the odometer push button easy to fix or is it worth the 100 bucks also dealer said they would set the actual miles to be correct ( I feal this one is too political to fix myself). And the throttle sensor erroe code 411, is this an easy fix or something that needs to be taken care of.
As a side note I am interested in buying some Bridgestone Potenza RE750's for my 1995 850 GLT I plan on getting 195/50/15R would anyone recommend the 205/50/15 instead? I can get the 195's for 82/ea
