2005 XC90 Door Latch issue
When I open the passenger door from the inside, then shut it, the door will not latch unless I toggle the door lock up and down, at least once... it doesn't do it if you open the door from the outside.. and the problem is intermittent... pretty frustrating though.
- Been thanked: 474 times
I recently had a different issue (can't open door from inside).
It was a detached door cable.
I wrote it up, so you can use this as a guide to open the door panel to look.
You may need to spray some silicone lubricant into the lock actuator to free things up.
DIY 2005 XC90 INNER Door Handle Fix (Can't open from inside)
https://www.matthewsvolvosite.com/forums ... hp?t=72385
