Customer came in with a bad clutch, over 400,000 km. I replaced it with a sachs clutch kit. new duel mass flywheel and slave cylinder.
I bled the clutch as good as i could ( vacuum bleed, helper pumping the pedal and reverse bleeding. I felt that the pedal was a bit soft, but I was able to shift the gears no problem with the car running.
Anyways at over 3000 rpm, the clutch slips.
So, I ordered another clutch kit, this time it was LUK, put it all together and the same thing, same pedal feel.
I have a clutch kit ordered from volvo for the morning, but these kits are volvo OEM. I do not understand what is going on. I made sure there was nothing behind the slave cylinder pushing it away from the tranny causing it to push against the pressure plate. Also the self adjusting clutch springs were compressed. From what i read that means it is pre-loaded and ready to go.
I ordered the duel mass flywheel from autocamping by the engine number. there were two available. The new one looked like the orginal, maybe there is a thickness difference between the two.
Any suggestions?
2005 volvo s60R clutch replacement
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I have attached the replacement procedure from VIDA that applies to your arrangement.
As far as I know, there should be a certain amount of adjustable free play at the beginning of the pedal's travel (like an inch or less, not sure what the exact value is) before it even starts moving the hydraulics and release mechanism.
From your description of the problem, it appears that the pedal is pre-tensioned and the first thing that comes to my mind is to check that play; the pedal should not be pre-tensioned; if it is, it needs to be adjusted.
M66 Clutch.pdf- (676.91 KiB) Downloaded 1393 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
