2006 xc 70 alarm issue
fields 100
Year and Model: s 60 T-5 2013
Post by fields 100 »
Hi all,
I am having an issue with a siren not sounding when alarm is set off. All other components operate normally. Should I just go ahead and try to replace it or there are some other diagnostics to run before shelling out $300.00 plus?
Thanks in advance.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Given it's a 2006, there is a chance only the battery inside the siren is toasted. I'd try removing the module, split it open, clean the circuit board and install a new battery if the board is not yet melted. The other option is to just disconnect the module and leave the car without alarm.
fields 100
Thanks so much for reply. Hopefully it IS a battery.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
It is a battery. Doomed to failed design (battery leaks electrolyte over electronics). Don't buy used, they all suffer the same problem. Either new siren, or repair your own (~$12 for a new battery plus some work).
http://www.volvoxc.com/forums/showthrea ... went-south
Siren is much easier to get to through headlight. Bumper needs to come off.
