98 v70 xc leaky turbo
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
So I replaced the gasket and oring on the turbo return line. The oring side was clearly leaking. That worked out fine, but now the turbo is leaking. Not bad, but there. It always seems I plug one leak and then there is another - like the oil finds the weakest seal. I was running semi-synthetic oil and switched over to synthetic after the repair. I'm wondering if running semi again will lesson the leaks a bit.
- 13 Replies
- 6057 Views
- 11 Replies
- 4199 Views
Last post by vtl
- 46 Replies
- 8775 Views
Last post by gswede
- 1169 Views
Last post by owowl
- 15 Replies
- 7044 Views
Last post by sjanssen15
