2002 V70 X/C Front Crankshaft seal
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
Can anyone tell me if I need to remove the timing belt to access the front crankshaft seal on a 2002 V70 X/C Turbo? I have a lot of the engine apart for 140,000 maintenance (PCV, Belts, Power steering, Radiator,thermostat) and would like to replace the Main Crankshaft seal if I don't have to remove the timing belt; Timing belt was replaced by Volvo at 120,000 miles.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
My recollection is you have to take off timing belt. Seal is in the oil pump, so belt is there. If you lock the cams you should not have a problem. You can mark everything and take pictures and make sure everything goes back as it came off. Not that big a deal
VolvoFred
Year and Model: S60 2002
Has thanked: 3 times
Post by VolvoFred »
Yes you have to remove crank pulley and timing belt gear from the end of the crank to pull the oil seal.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If not leaking, leave the crank seal alone. It should last some 200K miles in the 5-cylinder engine.
And yes, crank pulley must be removed to replace the front crank seal.
