Ok so on tear down mode. I don't see the reference marks for cam timing.
Can't seem to get the serpentine belt from around the crank pulley either
While this is torn down what else should be replaced. Water pump, idler pulleys thermostat?
Thanks
2001 head gasket
So after healing up from a fall- I got the head to the machine shop today. Its out 0.028"
Machine shop cant find specs on allowable milling and suggested a block shim.
Is Cutting 0.030 too much for the 2.8L heads?
Is there a shim available from somewhere.
Thanks
Thanks
- 18 Replies
- 5962 Views
- 504 Views
Last post by erikv11
- 3363 Views
Last post by oorhett
- 1388 Views
Last post by kmaninaustin
- 3405 Views
Last post by rspi
