98 v70 cam pulley fastener torque
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
What is the correct torque for the 3 fasteners on the cam pulleys?
I guessed based on the size and torqued to 20 -25 NM range. I had no tool to keep the cam pulleys from spinning and getting those fasteners on tight was tough. So as a "last little task" now that everything is buttoned up and the TB is on I think I'll put a torque wrench on them and adjust them if needed.
Also, can anyone tell me what the idle RPM should be? I ended up with around 925-950 and it idles smoothly. I guess I'm more curious than anything because I don't plan to change it right away if it's off by much.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
It is in the other DIY I linked to you recently...
https://www.matthewsvolvosite.com/forums ... hp?t=53722
98v70dad
Has thanked: 1 time
Post by 98v70dad »
cn90 wrote:It is in the other DIY I linked to you recently...
Thanks I didn't see them at the beginning. I read over the instructions many times looking for them and didn't notice the summary at the beginning.
