2000 S70 GLT-SE, Code P0236
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello all,
When i started the car this morning, it died immediately, started again, the rpm was rough and had to push gas pedal to keep the car running, after 10 seconds it came back to normal, then check engine light came on, obd gave P0236 code, is this the tcv code?
If you guys think i need to replace the part, can i just get the ipd's performance tcv instead?
Here is the link to it
http://www.ipdusa.com/products/8901/120 ... 70-v70-c70
If you think there is something else is wrong pls let me know.
Thanks.
