Ok, when the car is running at idle or at a light in drive it feels as if the car is running with a miss. I checked with a scanner and no misfires are present. There is a lean code coming up...... forget what the code # is but lean code for sure............. vacuum leak.......... would that cause a noticeable stumble specially at idle? Memory tells me that a vac leak will cause idle to be erratic........ once you get on the accelerator it runs fine.......
any help is apprecaited!
2005 V70 Stumble at idle
goldmandan
- Year and Model: 1999 S 70, 2000 V70
goldmandan
Ok I ran the scanner and looked for stored codes it showed misfire on multiple cylinders then misfire cyl 4 and 5 I swapped out these for some extra coils I had lying around. Idle
Did get better but still not perfect. The misfire codes didn't come back yet. Is there a way of checking the coils to make sure they are good??? Also would the lean code
Cause a miss like that??? I think so but not sure
goldmandan
Ok it was a bad coil replaced it and engine runs excellent again
There are some measurements of coil resistance in threads here. There are some cheap junk coils on the market which don't last the > 10 years/150k miles the originals do.
- 1333 Views
Last post by Dr. Mo
- 330 Views
Last post by patcal
- 14 Replies
- 2555 Views
Last post by OverTheHill
- 2593 Views
- 12 Replies
- 1557 Views
Last post by sleddriver
