Heater Core
adbalt
Year and Model: 1998
Heater Core
Post by adbalt »
I'm in the process of replacing my heater core on a 98 Volvo S70. The heater core i bought did not come with a foam strip to install and is not quite as wide as the original. Two questions: 1.) What does the foam strip do? and 2.) Any advice on what type of foam strip I should use?
Thanks for the help.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
The foam strip ensures that the air passes through the heater core fins and gets heated. Without foam the core will be less effective because air can just scoot around it.
No good suggestions for a foam alternative, I haven't had to do that, but I'm sure someone else will chime in.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
The infamous "Euro" core came with really thin foam.
I peeled it and replaced it with a thicker, adhesive
backed weather stripping foam. I had to trim the
thickness a bit at the tank seams, but it works well.
Year and Model: 2004 V70 2.5T
Been thanked: 470 times
Post by cn90 »
Go to Home Depot etc. and buy some window seal stuff.
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
Yes, you can get foam strips with adhesive backing from Home Depot. Won't be perfect but better than no foam.
