Hi Guys
Im just finishing off an engine swap on my T5R
Went to fire up this morning and No Spark
Have traced the fault to a 2 volt input to the cam angle sensor , by all accounts this should be around battery voltage
Swapping out the ECU has not changed the issue
Can anybody give me a lead as where to look next ? Where is the power put into the ECU Can I meter it ?
Is there an easy way to check the continuity of that CAngle wiring
Thanks
Low Volts to Cam Angle Sensor
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
There are 2 types of camshaft sensors: supply voltage is 12 Volts for both types, and signal voltages are 12 V or 5 V. I need to know your ECU and camshaft sensor part numbers to give you correct answer.
If my English is bad, please correct me
Thanks Azik09 Attached are photos of the hardware
Ive checked the cables from the ecu to the camshaft sensor , there is good continuity and no voltage drop
Even with a spare ecu installed i still get just over 2 volts at pin 3 on the sensor plug and less than half a volt on pin 2
I've been looking for the A6 pin ( ignition system ) on my onboard diagnostic system this seems to be missing
I only have 4 sockets installed on the A receptacle
- 772 Views
Last post by RobsS40
- 23 Replies
- 2524 Views
- 2266 Views
- 548 Views
Last post by mar601
- 28 Replies
- 4132 Views
Last post by RickHaleParker
