99 S70: P/S Fluid - ATF or Pentosin CHF202?
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
99 S70 N/A, 170k
The manual says to use ATF for the P/S system, but I've heard that using it will cause leaks. I know the 2002 and up years should use Pentosin CHF202 or similar, and not ATF as the manual says. But what about a 99? My fluid needs to be refreshed and want to be sure I flush and refill with the correct fluid.
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
krenekj
Post by krenekj »
This is one of the references that talks about the switch over in the 99-00 years:
http://volvoforums.com/forum/volvo-s70- ... s70-37026/
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
In reality I think either one will work fine in either car but you don't want to mix them. I follow the manual and use ATF on the pre '99s and the power steering fluid on the later models.
I made the mistake of dumping in some ATF into an old Jeep that used power steering fluid and it turned into a foamy gelatinous goo.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I've used Pentosin and Mobil1 ATF in my my '98 with no issues.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
