'88 760 Transmission AW71
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
88760RICH
Year and Model: 760 1988
Post by 88760RICH »
I am rebuilding this AW71 transmission and wondering how to remove and install the ring on the inner end of the output shaft. The ring appears to be hard carbon and approximately 12mm in diameter and square cut. Photos are attached showing the old ring still on the shaft and new ring in my hand.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
88760RICH wrote:Photos are
Where?
88760RICH
Post by 88760RICH »
93Regina
Post by 93Regina »
RE: "ring on the inner end of the output shaft. The ring appears to be hard carbon"
After years of heat, rubber becomes hard. Getting underneath it with a small screw-driver or pick, and then moving upwards should break it. I'd put some tranny oil on new one, and slide it over shaft.
Green Book Manual
Volvo AW-70 Series Transmission Rebuild PDF
88760RICH
Post by 88760RICH »
Thank you for the replay and the link /pdf. They are very much appreciated! :)
