940 AW71 92+ Bearing Oil Pipe Connector Part
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Mikedtx
Year and Model: 940T Wagon 1994
Post by Mikedtx »
Need a part number that Volvo seems not to provide or someone that has a spare. First time poster. I’ve been working my way through a 1994 Volvo 940T’s issues. This week it was the gasket on the extension housing and transmission mount. When I pulled the extension housing the pipe that routs oil to the bearing at the rear of the extension housing came loose. This pipe has three pieces a long pipe and rubber joint and a very small pipe to join to the transmission. Unfortunately, when the pipe came off this small pipe piece bounced into a deep crack in my garage floor (Broken cement due to age and soil.) Retrieving it is not an option without jackhammering the cement.
Anyways does anyone know the part number for this, it is item 8c on this page https://www.volvopartswebstore.com/show ... evel=24679
I put it back together without the oil pipe, but I expect the bearing with go within the next 10k miles due to limited lubrication and I’ll open it back up at that time and reinstall the pipe if I can find the part. Any help will be greatly appreciated.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Mikedtx wrote: 19 Aug 2017, 22:30When I pulled the extension housing the pipe that routs oil to the bearing at the rear of the extension housing came loose.
Post for a part over here in Wanted
