Hi all,
My V70 takes extremely long to come up to temperature. But it does finally get there when I get to the highway after 20 mins. or so. My XC in comparison is up in 5 mins regardless of how I drive or even if it is just idling.
From experience with older Volvos I know that if a thermostat fails the car simply won't reach temperature. So my question is could there be something else wrong?
It looks like I can't just drop a new one in, FCP only sells a whole unit with housing and temp sensor and the thing is pricey.
Thanks, Dirk
05' V70 thermostat bad?
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 1611 times
- Been thanked: 4075 times
I'll be following this one closely as VP of the 2005 stick shift club
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The unit inside looks like this one
http://www.ebay.com/itm/291568334911?_t ... EBIDX%3AIT
There is only on confirmed owner to have put this in a gasoline engine saying it worked fine. You will need to split open the housing and reuse the gasket or add some rtv stuff for water pump. This shows how to split the housing for a non turbo (the turbo housing has an extra pipe connection)
To check yours start the engine from cold and let it idle for 2 min. If the radiator hose going to the t-stat housing got warm then the stat is stuck open (quite usual for an 8 years Volvo). The car will reach 12h temperature even if the stat is stuck open. It will just take longer.
- 850 LPT
Thanks, I don't know if I want to be messing with splitting the housing to save money.
I think I will just bite the bullet and replace it, FCP has it for $109
Question though: I just look at the thing since I pulled the car in for an oil change anyway.
The bolts are very obstructed by the power steering pump, does that have to come out or is there a trick?
13' Honda Odyssey
13' Honda Odyssey
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
(Ignore link I posted). You can take off the timing belt top cover (two T-25 screws and the two clips that hold it to rest of timing cover). Drain off about a gallon on antifreeze. Take off accessory belt. Remove the 3 bolts on power steering pump and set it aside. Disconnect radiator hose at thermostat housing. Unplug ECT sensor. Use a T-25 and remove the 4 bolts. Install new unit (make sure the metal gasket came off with old thermostat of course). Reverse steps.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
MarcM
One thing that will save you more yelling, screaming and swearing than you'll ever imagine? One of these right here:
http://www.ipdusa.com/products/11344/12 ... -p80-p1-p2
It'll save you running around looking for a Torx driver for 1/2" drive that is shallow enough to get in there. (3/8" ratchet is too short and tensioner is tough). FCP doesn't have these. If you were nearer NH, I'd loan it to you. Before I got it, it took me 2 hrs solo (with a 3/8" ratchet) and my neighbors all ended up learning all kinds of new words.
This thing is an absolute MUST HAVE.
2005 S60 2.5T AWD
IPD mods:
IPD mods:
Just add a pipe to the 3/8 drive handle and you can relieve serpentine belt tension. Tool is a bit steep in price unless you have lots of cars with multiple applications
- 850 LPT
Marc, Steve, thank you guys for all the tips.
I will tackle this next weekend since I have to order some stuff.
I have to agree with Steve, the tool from ipd is expensive. It's great when you need it a lot though, then you get your payback.
Since I still had the car in the garage, I tried a 3/8" drive torx socket on a regular 3/8" bar and it seems to be working fine. I was able to release tension on the belt with no problem. And there was enough space to get my hands in there.
13' Honda Odyssey
13' Honda Odyssey
- oragex
I use one of these https://www.amazon.com/Stanley-92-645-8- ... B000NIK9XM but before I was also putting a 1ft pipe on the ratchet handle. You may want to get a picture of the serpentine belt path printed upon renstalling the belt, I can never figure out by myself how to pass it on the pulleys
Bingo
