new injectors 850 GLT
jantt
Year and Model: C70 2000
Been thanked: 2 times
Post by jantt »
Hi
My 850 GLT 1992 comes from factory with 200 cc injectors and I just installed 315 cc injectors.
Now the engine is a bit shaky and code 5-1-2 comes.
Is it because the new injectors just have to be driven in or can I not just install larger injectors ?
jantt
Post by jantt »
Had to put the old injectors back and it drives fine again.
Waste of money to buy new injectors.
Thought with more air intake, larger injectors and my chipbox (doesn`t seem to work at all) I could get some more power.
Have to wait to I get money to a turbo.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Cars are ENGINEERED to run good/perfect with the installed rated equipment. If your injectors are faulty, you have to get injectors with the same cc flow rate.
If you are looking for more performance, do yourself a favor and purchase a faster car. Fortunate for you, there is a similar model that comes turbo.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Larger injectors alone don't result in a more power.
You will need a lot of things for just around 20-25 hp gain max on a non turbo engine.It just isn't worth time or money.
Turbo engines are totally different story.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
