No start after spark plug change
2005volvos40t5
- Year and Model: 2005 S40 T5
I have a 2005 S40 T5 -- I changed the spark plugs 2 days ago - after changing the plugs the car started and ran better than before-- Today i start the car it started and after 10 seconds of idling the RPMs went all the way down and the car turned off on its own -- Now the car will not turn over -- i checked for spark and YES it does spark -- i dont know if i should check spark on each plug or not but i did check it on the first plug on the left and all good -- I am totally lost as far as what is causing my car not to turn over -- Any help or guidance would be greatly appreciated. Thank You
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I would first do a nice visual - there was something loose that eventually came off.
If it does not turn over, that would be the starter solenoid, no? Can you hear the 'click' from the solenoid when you try to start?
There are some quite helpful no-start troubleshooting videos made by rspi (Robert DIY) on youtube, you might want to check those out or just search posts by rspi in the forum
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Check your battery voltage, and do the visual check of your connections.
Current Volvos:
- 3052 Views
Last post by Roger_850T
- 11755 Views
Last post by MoosePond123
- 3890 Views
- 1943 Views
- 1447 Views
Last post by amblerman
