Engine knock after spark plug change Topic is solved
MoosePond123
Year and Model: s80 2000
Post by MoosePond123 »
Hi, Need your help!
I changed the spark plugs on my 2000 S80 today. After installing the new plugs I started the engine it and there was a serious knock. When I shut the engine off air rushed out of the engine thru a valve in the front drivers side. I thought the problem might be the new spark plugs so I put the old ones back in and the knock remained. When I installed the new plugs I gently loosened up some dirt in the spark plug wells and vacuumed it out. One of the spark plug wells was dirty which I was told was probably blow back from one of the spark plugs that was not seated properly due to dirt or debris which made a lot of sense.
Does anyone have a suggestion as to what is causing this sudden engine knock? It wasn't there before I changed the plugs.
Thanks!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
I would double-check the connection to the wires. Make sure they're seated on the plugs.
Also -> Amazon link
MoosePond123
I pulled a coil pack boot off the spark plug one at a time while the engine was running and each time the engine ran rougher.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Could somehow a nut or screw fallen into one of the open plug holes?
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
MoosePond123
The reason the air was rushing out when I shut the engine off was because there was a connector from a small black vacuum hose to a nipple on the drivers side of the manifold that had split. I was able to cut off the bad section and reattach. Engine is still knocking.
MoosePond123
I don't think so. All bolts for the coil packs and covers are accounted for.
MoosePond123
I think further investigation will require removal of the cam cover which is probably best left to a Volvo specialty mechanic. Do you agree?
June
Post by June »
I agree. I would not start it again and let your mechanic start it. In case the engine is damaging itself.
My Volvo cars owned
1996 960 ordered
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Post by difflock54 »
Was going to suggest that the new plugs were the wrong ones (i.e. too long so hitting the pistons at the top of the stroke) but as you replaced the old ones without the knock dissappearing that theory is unlikely.
MoosePond123
My mechanic looked into the spark plug holes with his scope and didn't see anything unusual, so he turned the car over a few times with the plugs out to blow out anything that down there, then shot some compressed air into the spark plug hole. He reinstalled the plugs, started the car up and it quieted right down. He thinks it was a piece of plastic. I had recently replaced the plastic hoses that surround the coil wires because the old ones had disintegrated into tiny bits, some of which were hidden under the coil packs. So he didn't have to get into the cam cover which is good news. Thanks for your input.
