Removing stubborn ABS module bolt
VolvoS70Driver
Year and Model: 1998 S70 GLT
Post by VolvoS70Driver »
I did some searching but couldn't find a thread specific to this but I got all the turbo hoses and vac lines and such pulled out to replace some PCV parts and put in new rear cam seals. While I have it down this far I am thinking I will try again to get the defective ABS module out to rework the solder joints as it has been bad since I bought the car. Last time I got three bolts out and the bottom rear bolt decided it wasn't time for it to leave the nest and I ended up with some type of custom shaped bolt head.
The little torx socket still fits over it but there is not enough bite to make anything happen. Really, just trying to get some suggestions for getting that bolt out (I got extras from an old module to replace the bad one so no big deal if I destroy it). Limited room under the car as I had to work this repair outside due to an overcrowded situation in the shop so will be a challenge if I have to access it from the bottom side.
Any suggestions would be very appreciated.
Doug
1998 S70 GLT Blk/Blk
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Buy the best quality tool you can find. maybe a new high quality tool will bite just enough better to get it loose versus a tool that is used, cheaper built, or worn one. other than that, Mini dremmel? part is shot anyway. May void a core exchange though.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Dremel with a grinding bit.
I have $2 sockets and $12 e5 sockets, when those bolts bond to the sleeves on the module and the heads are corroded it's game over. It wouldn't hurt to try a 4mm but once they get to that point it is what it is.
When I swap out a module and hear that "snap" noise when the bolt breaks free it's like some sort of gift from God. I hate life when they strip out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
Something like this might work, the 3/16 size is less than 5mm.
https://www.amazon.com/Tools-Power-Grip- ... 1KTNZBC380
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
Been thanked: 35 times
Post by MadeInJapan »
I recall doing this years ago. I got a set of the reverse torx at Napa. Until I got the right bit it wasn't happening.
Has thanked: 1610 times
Been thanked: 4065 times
Sometimes you can drop down a size on a heavily corroded washer and work it on to the fastener, remove clean, and repeat 8 times until you get a good amount of tool onto it.
I removed one of mine on my 1999 with a sharp needle nose vice grip (TM) when it was corroded. The (TM) is important there, don't use a POS tool here.
combatkarl
Year and Model: 1997 850 GLT
Post by combatkarl »
I had the same issue when removing a ABS module from a vehicle at a salvage yard. I ended up removing the hard-brake lines and the mounting bracket attached to the inner fender.
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
Has thanked: 2200 times
Been thanked: 1852 times
I'm going to throw this out there as I have not done this myself.
What about grinding the head off the stubborn bolt, sliding the ABS module off and then having more access to the remaining bolt shaft to get a grip with vice-grips to loosen and turn it out. You said you have spare bolts.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Neil, that's exactly what MattyMoo is suggesting, you are on the mark.
I've done it once, it is not too bad of a job, depending on which bolt it is. The one in the back is really tough to see while you are grinding, I used a mirror and still butchered the case a bit. Others have done better and not hit the case much at all. But anyway you must use a Dremel type tool to grind off the head, given the tight access.
About the spare bolts: any time I remove an ABS module, it goes back in with new, hex head bolts.
we actually had a thread with the source for the bolts here recently...probably a smart thing to use SS bolts
