ABS and STC warning lights Topic is solved
got.milk2
Post by got.milk2 »
I have a 1999 S80. The ABS and STC light comes on every few days. If you shut the engine off and restart they go away. Any ideas?
digital2
Post by digital2 »
If problem with sensor then light is permanent.
If connector is bad or wire is broken inside harness but still touching then you get intermittent light coming on which is alleviated when you switch off engine. When engine starts computer senses everything ok. After warming up and or hitting some bumps connection is broken and light comes out. History repeats itself. This problem is common in the 850/s70 series.
