Ok, Im really a cheapskate.... (oil use question)
Has thanked: 1610 times
Been thanked: 4065 times
[flash=]r[/flash]My 1999 uses about one quart of syn every 1500 miles...my BMW X3 about one every 6000 miles.
My fun car, the 2003 VW convertible, doesn't use any oil, but I put so few miles on her in a year that she gets 5 new quarts of SYN once in April, and last year I only drove it 3000 miles.
Yes. You guessed it. Can I use this like new oil to top off the two 'guzzlers' or does that mark me for the Cheapest guy on MVS??
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
Does it have a milky look to it? If it does it has moisture in it - the bane of people who barely drive their cars. And if it does, I'd toss it.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
That is about normal for a turbo car driven around town. Actually it's a little low. I would just top it off with fresh oil.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
rspi wrote:That is about normal for a turbo car driven around town. Actually it's a little low. I would just top it off with fresh oil.
1 quart for 2500 normal? Seems a little high to me. My 2000 XC w/233K will maybe drop half a quart over 5000 miles, even with the brutal Southern summers.
As far as the original questions, topping off your car with "used" year old oil should be fine and I wouldn't worry about it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Haha I have a brother in arms!! :) :)
I would reuse the low mileage stuff however I'd leave the notor iding for about thirty minutes with the oil cap off to ensure that any moisture evaporates out the top of the engine.
If you leave it in without doing the cap trick the moisture will vaporize and just get recirculated by the PCV system.
The oil comes out amber colored, indistinguishable from new. I always give the Beetle a hot run so there is very little moisture in the used oil, and certainly no milkiness.
The usage is a combination of a burning and a bit of seepage on the right side of the engine. I wouldn't worry about introducing water into the other engines as it would be gone the first time drove these in normal use.
I think Im going to go for it for a year.
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
I dump in a half quart every 1000K. Mostly freeway driving. Never see any white smoke, smells a little oily from time-to-time, despite no drips or apparent wet spots on the motor. Glad to know this kind of oil consumption is "normal". Can the oil consumption be eradicated, or is it not worth the time?
Correct me if I'm wrong, but it sounds like you're implying this kind of oil consumption might not necessarily suggest something is wrong with the car?
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote:or does that mark me for the Cheapest guy on MVS??
To answer your question: yes :lol:
Honestly Steve, topping off with used oil just doesn't sound like the right thing to do although it is probably ok.
Here is another idea too: Why don't you change the oil in the Beetle every other season to actually make good use of it?
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
dosbricks
Post by dosbricks »
Since the '99 is not all that much fun to drive (all that stick waggling during boost), then used oil is probably good enough for it. :wink:
Has thanked: 2200 times
Been thanked: 1852 times
Yes you are a cheapskate (and that is coming from a Scotsman!!).
Other things to consider with old oil is possible leak-down of fuel into the oil from a little used car, condensation particularly over colder months.
Synthetic will naturally resist this better than dino.
You do the right thing in using the car regularly and giving it a good long run is better than a series of short runs.
As you do such a small mileage, why not just use dino or semi-synth to reduce cost?
In the end it is your car, so do what you are comfortable with and karma will be your answer!
