My next NEWB Question--Should I disconnect AWD?
BBslider001
Year and Model: 1998 V70 Wagon
Post by BBslider001 »
I am wondering if disconnecting the AWD in my V70 would help with mileage, performance, and driveability. The car is a pavement queen and will never see snow/ice/muddy conditions. Has anyone else done this and is it a big deal? It also clunks first thing in the morning when I first start backing up. It almost sounds like it is bound up and frees itself. It doesn't do this any other time, only in the morning first thing.
1998 V70 Wagon
1997 Ford F-350 PSD, slightly modded
2011 Heartland Sundance 34' RV
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Tons of people have converted to FWD. With the P80 vintage cars all of the AWD's fail at some point. Mileage should go up but I don't know by how much.
Has thanked: 2200 times
Been thanked: 1852 times
I reckoned that In city driving our 850 auto GLT (non-turbo) returned around 26 mpg (UK gallon 4.5litres = 1 gallon), and out 98 V70 XC did about 22-23 at best. It was on highway we sow a bigger improvement of 37-40 v's 31-33mpg.
So you should see an improvement of 10-15% in my estimation as a minimum. The only part I am not sure is unless you remove the angle gear, it still causes drag, you also have the rear axle and weight and drag of the rear diff and shafts so you may not see as much of an improvement as you think.
I'd first look and see what is causing the clunk. It may be an engine mount or a worn out bushing, and not the AWD system at all.
ID the issue and let us know.
Good luck!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'm a big proponent of AWD.
I've run with and without and
IMHO, the car handles better WITH.
Much stickier and changes lanes better.
AWD also completely cancels out torque steer.
Pull your rear rotors and inspect the
E Brake drums and shoes for your clunk...
Just stay on top of tire condition.
P80 AWD Must have matched rubber.
I agree with the AWD sentiments, but unless you are planning to do a lot of skiing or off-road driving, the OP would appear to live in CA where AWD is not really needed. The clunk is likely a parking brake issue which is a great call that I missed on. Good catch!
BEJinFbk
Post by BEJinFbk »
I'm talking about dry pavement.
AWD makes a significant difference.
Anytime I've run my car sans driveshaft,
I Could Not Wait to have AWD back.
And sure... It's Awesome on snow and ice! :wink:
But that's just me - Your results may vary. :mrgreen:
