door handles stick on 240
doctormcbainmcbain
- Year and Model:
the drivers side door handles catch on trying to open. You have to either pull up on the door lock or press on the interior door handle and at the same time use the outside door handle. sometimes it will work with the key and pulling the handle. I tried adjusting the barrel as they say in the Haynes book. It seemed a liitle better, but it still does not work right. Any help?
DVolvoguy777
- Year and Model:
The cam on the door handle mechanisim is worn out. You can go to the JY and get one that is good. Take the old handle out and compair it to the one of the others on your car that is less used and you will see. Or you can swap one of the passenger door handles for the drivers door.
I am a current Volvo 850T5 owner. Have had '67 144ES, 71 142E, 76 245DL, 80 242GT, 81 245DL. Still wish that I had the 142E.
I scored an '06 Harley Dyna Superglide for Fathers day.
doctormcbainmcbain
- Year and Model:
Thanks for the help on that door handle problem
