2007 S80 3.2 V6 Front wheel drive
I have isolated the drain down to the #37 fuse, fuel injection fuse under hood.
I have to listen real close in engine compartment hear a faint high pitched whine after turning engine off, until I pull the #37 fuse.
Battery dies after 24 hour of sitting without pulling fuse. Can sit for days and not die if the fuse is pulled.
Any ideas?
Battery Drain Fuel injection
jimmy57
- Been thanked: 322 times
Are you sure it is #37? That shows on wiring diagram to be MAF and the injectors only. Injectors buzzing would flood engine, maybe even hydrolock it if you attempt cranking. MAF sensor wouldn't make noise.
- 3847 Views
Last post by marmotteNZ
- 11 Replies
- 6092 Views
Last post by xanthefin
- 2548 Views
Last post by loosenut
- 15 Replies
- 4084 Views
Last post by dikidera
- 243 Views
