Did it give you any codes to back up flashing that pesky arrow at you?
- S
Transmission fault indicator
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Well, maybe it was a temporary bad electrical connection due to the bumps. Especially if it goes away by itself.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I'm not quite as optimistic. If the arrow is flashing then a code should have been set. You'll need a dealer or another shop to read the transmission code(s).
In the meantime check the transmission fluid level and its color.
polskamafia mjl
I'm assuming you meant its halfway between the two marks on the dip stick?
To tandem this... I had a similar issue and created my own post... but cant find answers...
My followup to my initial post...
All right... pulled the dipstick tube...it was cluttered with gunk... cleaned it out.. FLUID WAS able to go in!!!! Yay...
Put in 2 qts... she moved and drove without a hitch or hesitation rather!!!
So I say... TEST DRIVE to myself on the slab...
Go through gearage just fine... no slip or nothing....
THEN... outta nowhere... stalls out... tjrn engine off wait 10 mins... she goes back into gear... yay!! ( I've deduced it's a low fluid issue).
I move 20 ft.. and the driver axle pops out AGAIN!!!
SO, what causes this? 3rd time, 2 axles... and lost 6qts of fluid....
Circlip, Alignment and Torque mount???? Possible struts?
^^^ could this save me a shit ton on a tranny replacement
- 2490 Views
Last post by TripleThreat719
- 771 Views
Last post by Joncanland
- 13 Replies
- 2467 Views
Last post by ferocity02
- 2596 Views
Last post by dfk
- 929 Views
Last post by Vanillagrila
