Replacing master cylinder, I came across 2 plastic (nylon) 'hoogies' in the inlets where the reservoir installs.
Anyone know what these are and their importance / function?
Disc bottom w/ 3 holes(ports) and a post sticking up towards reservoir.
Rebuilt Cardone doesn't come with them,so.....
master cylinder parts
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Are the pieces you're referring to shown in the image below?
- whilst
- Year and Model: 1995 854T
- Been thanked: 2 times
Nope. Are you referring to reservoir 'nipples' for ABS feed? Or a clutch.
I'm talking about inside master, they are under rubber seals for res and protrude up through and into reservoir 'pipes'.
FCP sent me a PDF blowup. #8 for those with VADIS,etc.
I've come to believe, that they are in there to prevent "bottoming" out of res tubes into Master.That would hinder flow,possibly stopping it altogether.
They help fluid 'feed' into it, hence the 3 port holes in bottom disc.
My reasoning,anyway.
Best,Jeff
Best,Jeff
- whilst
FYI: Volvo dealer printed out Factory info sheet on brake hydraulic system.
"The brake fluid reservoir connectors have >safety valves< which are normally open. If the reservoir comes loose(?), the safety valves will shut to prevent brake fluid escaping".
I personally don't see how they could work that way, since they have 3 holes in the bottom disc...?
A puzzler for sure.
Now you know.
A puzzler for sure.
Now you know.
- 6972 Views
Last post by 850forum
- 272 Views
Last post by clifford06
- 1032 Views
Last post by polskamafia mjl
- 824 Views
- 768 Views
