August 1996 to August 2016 makes it 20. Owner of record since mile one. Anyone out there with such a feat?
The headliner now hovers over the head, resting -- girls complain about their hair. Driving with windows down makes fabric flutter, enlivens my scalp.
I'm thinking about removing headliner, and restoring it with a 200,000 mile outlook. There are several helpful threads since Ozark Lee's from 2004(?) write up.
Once unfastened, would the headliner slide out via the trunk (rear seats folded)... what glue... how to hold it up to install... others?
TIA!
97 854: 20th anniversary project - headliner
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I wrote up some comments to a thread a while back. If I were to do it again, I would opt for something other than the JoAnn Fabric headliner material option -- it is ever so slightly too think. I'd try to find more original type materials, which someone on here has done if you sift through enough write-ups. I used 3M headliner adhesive.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
xHeart
Helpful!
xHeart
Expansion tank, filler cap, and level guard
The cooling and heating parts were replaced in past four years (40k-miles) that started with radiator replacement. The expansion tank is the last item in my list.
Any suggestion on parts. Is URO a good replacement?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
I pulled a clean headliner out from the trunk from a junker parts car. 1.) it gave me practice handling the headliner and removing the brittle trim and other necessary things before I removed the original one and 2.) I had the parts car already. 3.) don't have to buy and re-glue new fabric
Suggesting a P&P if you have one near you but you'd probably need a van to take the head liner home in.
Regarding URO - If you are keeping the car for another 20 years then go with blue box.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 35 times
Right- the URO- they tend to break right where you attach the small hose to the thermostat, so be careful attaching that hose...that said, I think it's fine to use this item from them, but like cuhfs said, if you plan on keeping this car, then go Volvo, or pull a Volvo one from a junk yard- they do keep that nipple better than the URO.
xHeart
OK - All Volvo for $100 -- tank, cap, and level guard.
Anxiety, thinking about getting another car.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
My tips:
- Be careful and gentle when taking off the old headliner fabric. Wear old clothes that you can chuck afterwards. If you get any on you, rinse your skin off with cold water - hot water will dilate your pores and you will be itchy for a week.
- Use foam-backed headliner fabric. Anything else, the glue will seep through and look :c, which will make you >:[
- When gluing the fabric onto the board, use headliner adhesive. Do a few practice pieces beforehand. When evaluating these pieces, bear in mind that the tensile load the glue will experience is ~nothing, as headliner fabric is not particularly dense..
- Don't use too much adhesive, it'll make your fabric all squishy and gross instead of pleasant and poofy. When you've put on too much adhesive, it'll still look like you haven't put on enough. (The practice piece is in part for calibrating when you've got enough glue down.)
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I followed RobTheMod's for removing and installing the headliner which was to bend it around the front seats and pull it out the passenger side door.
I used JoAnn's Fabric and had good results; just make sure to get foam backed material. The hardest part for me was trying to spread the material out once the adhesive was applied; I recommend a second pair of hands for that part.
Some helpful references:
https://www.matthewsvolvosite.com/forums ... =1&t=34979
https://www.matthewsvolvosite.com/forums ... =1&t=26848
https://www.matthewsvolvosite.com/forums ... =1&t=47169
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I now have my 854 headliner on the work bench and am nearly ready to tackle the reglueing. I've had this out before and both times have pulled it through the trunk. Just drop it on the front headrests and with rear seatbacks folded forward pull it through the trunk. You have to bend-arch it a bit
but it slides out quite easily.
Cleaning out the dried residue from the deteriorated foam and glue under the loose flap is a challenge. I'm using a soft fingernail brush and vac with crevice attachment. This will probably be key to getting good adhesion.
A Joann Fabrics clerk advised me to use 3M Trim Adhesive (I think Ozark Lee has also recommended) but I couldn't find it locally so the suggested alternative is 3M Adhesive 77, which I will test on some scrap fabric.
The visors (10 mm hex) need to come off; cut the wires midway down the A pillar, they can be spliced with crimps. Remove the courtesy light panel ( pop out the lamp lenses and 2 T 10 screws). Remove the mirror.
The plastic trim removal tools sold by HF are very useful for your trim pieces. There's a tutorial on removing them on this forum. One special note, though—the plastic retention ring around the sun roof if you have one. It has 2 locking tabs spaced along each long side at about 1/3 and 2/3 points (not in the middle as I recall). If you have strong fingers you can grab the piece and sort of turn it inward while pressing toward the center to bow it away from its edge. I used a plastic tool like a broad knife and a short piece of 2x4 to tap them loose on my first one, which worked. They can become kind of brittle over time but my experience has been they will bend enough to detach the long sides then pull the short sides loose.
While you have it out, detach your sun roof drain tubes and blow them clear. If clogged, run a stiff wire down them to push out debris.
It's a bit of work but you'll know you car more intimately once finished!
- 1316 Views
Last post by Ben850
- 4263 Views
Last post by BlackBart
- 384 Views
Last post by Baptiste1106
- 2912 Views
Last post by rspi
- 26 Replies
- 6913 Views
Last post by 98v70dad
