S70 engine swap
Reming870
Year and Model: 2000 S70
S70 engine swap
Post by Reming870 »
Ok. It died. We did everything to save it
Found a line on an engine for about $500.
Seems easy enough to change.
Anything I should be aware of? Programming, specialty tools?
Reming870
Post by Reming870 »
Ok
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Are you doing the work or someone else?
It'll cost more than $500.
https://www.matthewsvolvosite.com/forums ... =1&t=76509
85 GLH, 367 whp
00 Insight, 72 mpg
Reming870
Post by Reming870 »
I'll do it myself if I don't need specialty tools that are too expensive.
$500 in parts to do myself?
dosbricks
Been thanked: 2 times
Post by dosbricks »
$500 is reasonable because there may be stuff you will want to replace while you're in the process, like engine mounts, seals, hoses, water pump and TB components. It will be easier if you already have experience pulling control arms and axles. All in all, it's not a difficult job--just requires methodical and careful work.
I don't recall any Volvo specific tools required. A set of wobble extensions is helpful.
Has thanked: 1836 times
Been thanked: 1709 times
Are you using an engine from the same year?
Reming870
Post by Reming870 »
Yes. Same year engine. Was hoping not to spend anything more than $100 in misc parts.
Reming870
Post by Reming870 »
I also posted it for sale as it has a new xemodex and brakes. Body and interior are near perfect. It's a shame to see it go.
tryingbe
Has thanked: 1 time
Post by tryingbe »
Reming870 wrote:Yes. Same year engine. Was hoping not to spend anything more than $100 in misc parts.
Timing belt/waterpump/tensions/etc will run you around $200
Seals are another $50
Good engine mounts will run you $200
All fluids, another $60 or $100 depends on what you use.
Misc vacuum hoses $20
Whatever else you find broken.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 1497 times
Been thanked: 3810 times
There's an accident victim in NH that you might be able to buyback for $300 if you move quickly. See P2 forum
Buying new parts $500 is way too light
