I am installing a pioneer AppRadio for my 2004 S80 Volvo car, anybody know where to find reverse control signal from front fuse box or around of backup gear? i know i can find it in truck fuse box, but i don't want to run a wire from trunk, i am looking for closest connect point in front.
also for volv s80 car, where is ground connection in trunk fuse box? seems i cannot find it.
also i need to find constant 12 v supply in trunk fuse box, anybody know? many thanks.
where to find reverse signal around of backup gear?
s80volvo2004
- Year and Model: 2004 S80
I just see your post, I have installed the Appradio on my car, the reverse signal is connected correctly, the backup camera provides reverse wire, i don't have the issue with it. But i still have problem with dimmer sire connection, i cannot find the dimmer or lighting switch wire from S80, leave this wire open, then the screen has the same brightness.
s80volvo2004
are you in san jose now? can we have a talk? thank you.yagger wrote:Next week, I will move to San Jose. I can help you with "wires questions". ))
