I've been monitoring my S70s coolant temp with torque using an OBD2 bluetooth dongle.
What is normal operation for these cars?
Cruising down the road temps stays normal at 190-195ish. When stopped for any reason temp climbs to 210-215 until the fan comes on. Seems hot to me.
No sign of a blown head gasket, leaking coolant or anything like that.
Temp gauge stays pointed right at the 3 oclock position the entire time.
Engine Temp question.
- Year and Model: Many Volvos
- Been thanked: 76 times
Perfectly normal. A tad low if anything but there is natural variation from sensor to sensor. Keep in mind that, even if it were pure water and not coolant, the water will not boil at 212 degrees since it is under pressure. Typical coolant at 12 PSI boils at around 260 degrees.
Snotrocket
- Year and Model: 1998
Thanks for the info guys.
I was thinking anything over 200 was the danger zone!
- 1357 Views
Last post by FLXC90
- 1321 Views
Last post by richardgengle
- 11 Replies
- 9011 Views
Last post by oragex
- 986 Views
Last post by rguzz
- 712 Views
Last post by lummert
