My S60 has been an absolute beast for the past couple of years but i now have one problem. The air conditioning wouldn't turn on!! After the car warmed up or my speed increased i was able to get the blower to come on. The blower comes on but not to full speed. Now i have done a little research and i think it maybe the regulator or the blower or possibly the switch. Is this a common issue with the P2s? Can this job wait a few months or will it end up hurting other components? Having changed the breather box(i forget the exact term in the vacuum line) a couple of years ago i feel that i can tackle this issue.
Thank you for your help,
Mick
Air Conditioning Problems
mick_jenkins
- Year and Model: 2004 Volvo S60
- Has thanked: 1613 times
- Been thanked: 4078 times
If you turn the fan control and don't get more air flow it's usually the blower motor. It's a tougher job than the earlier cars, maybe a 2.5 Rating on the MVS mechanic scale, https://www.matthewsvolvosite.com/forums ... =1&t=77006
mick_jenkins
the blower is still affected by the fan control but will not blow as hard as it did a few weeks ago. i will check out the scale right now.
mick_jenkins
Thank you for your answer. I'm gonna get a new blower. Should i change the regulator too?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I don't understand well, does the a/c button turn green when depressed? Is the a/c working at all?
Separately, the blower will sometimes burn the regulator, and also the motor will get seized because of rusted bearings. I'd pull the blower and check by hand if it turns easily, if it does I'd look into the regulator.
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
Before blaming the blower or a blower bearing, one could also possibly have:
1) A bad resistor pack for the fan motor (this is a good "junkyard part" opportunity if you are patient about pulling your own parts at the scrapyard).
2) A corroded or bad fan speed knob rheostat, the first approach being to disassemble the knob control panel from the CCM, and spray it with an electrical contact cleaner, such as DeOxit.
3) VIDA may help - there may be error codes that might give you a clue here.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
mick_jenkins
everything is now functional except when the blower is on full blast it sounds a little louder than usual and doesn't blow as hard as it did in the past. Only a couple of times did it fail to come on and i had to increase my speed to get the blower going. So i assume that the blower may be on its last leg. I will pull out the blower and look at it, its so hot here i was waiting until it cooled down before i had to do it. Has anyone had any experience with after-market blowers, if so how was your experience?
Thank you,
Mick
Thank you,
Mick
- 733 Views
Last post by 2006XC90user
- 1179 Views
Last post by patcal
- 1716 Views
Last post by erikv11
- 774 Views
Last post by jimmy57
- 596 Views
