Watched a video and read the guide on here, but had a few questions:
Checked again and the outers had about 1/16" of play so I assume that it should be zero and the tie
rod ends need to be replaced - is that right?
Just to be sure I've got it right here, when I loosen the lock bolt on the inside there is no danger
of damaging the rack since the rack end has the other ball joint and can rotate freely? Might
move the boot a bit but that's fine, I assume.
1996 850 Wagon - First Time for Tie Rod Ends Topic is solved
- Year and Model: Many Volvos
- Been thanked: 76 times
Any discernible play in a tie rod end is too much and, yes, the inner tie rod will rotate so the rack is indeed safe.
It is pretty rare for them to come apart altogether but it will just eat the tires alive.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
How does it feel when you drive? The part is cheap and the job is pretty easy (outside of cracking the jam nut loose), although you will need an alignment afterwards. I wouldn't wait 5k to fix it - even if it doesn't break, a car with sloppy tie rods is no fun to drive.
- 2692 Views
Last post by manovlov
- 2639 Views
Last post by shiloh51933
- 558 Views
Last post by dairyqueen814
- 1385 Views
Last post by E Showell
- 721 Views
Last post by vtl
