96 850 Turbo Rough idle and die Topic is solved
volkans80
Year and Model: 96 850T5, 08 XC70 D5
Has thanked: 1 time
Post by volkans80 »
Hi,
My 850 (Motronic 4.3) started to random rough idle and sometimes dies. Spark plugs (bosch), plug wires (bougicord), distributor & rotor (bosch), o2 sensor (bosch), PCV system, turbo's small air hoses and vacuum hoses are new. First times there is 232 231 435 and replaced o2 sensor error codes gone but problem not changed. I doubt crankshaft sensor because one year ago car stopped running and i cleaned crankshaft sensor. Also there is strange behaviour. Sometimes when i push gas pedal it starts accelerating and stops, rpm downs a bit and then starts accelerating then repeat same thing.
Is crankshaft sensor can immediately cuts firing and lets it continue?
Is crankshaft sensor can effect idling?
Thanks,
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
The most probable possibility that's missing from your list is the MAF. Unplug it, start the car and see if the car idles / runs better without it. If it does, you've found your problem.
- S
[Sold] '97 S70 T5
volkans80
Has thanked: 1 time
Post by volkans80 »
But mostly the car is running good. For example today i drive the car about one hour everything is ok but when i parking it die 6-7 times. 20 minute later i drive the car again 30 minute everything is ok. Two hour later i drive the car 30 minute everyting is ok. There is not a rough idle today but it died 6-7 times while parking.
Do you recommend unplug MAF and drive the car 1-2 days?
Sommerfeldt
No, don't do that. When you're idling rough, stop the car. Unplug MAF. Start car. See if problem goes away/gets better. If it does, get a new MAF.
- S
[Sold] '97 S70 T5
volkans80
Has thanked: 1 time
Post by volkans80 »
Ok I will try this. Thank you.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Is there a check engine light? What are the P codes?
volkans80
Has thanked: 1 time
Post by volkans80 »
I don't know P codes but first times there are 232 231 435 dtc codes. When i changed o2 sensor all gone.
I don't know if it is related but yesterday i checked wastegate rod by hand and I just read codes again and now there is only 414
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Since you have intermittent problem and it points towards the Maf...i would try a zip tie method on Maf's connector.That's a common fault on these cars.
Did you reset codes and ecu after o2 sensor replacement?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
volkans80
Has thanked: 1 time
Post by volkans80 »
Yes maybe MAF's connector loose. I will try zip tie.
I cleaned codes but not ecu. How can i reset ecu? If i disconnect battery, ecu resets?
misha
Post by misha »
After you zip tie Maf's connector,remove battery cables for around 15 min in order to reset ecu's fuel trim.
Maf connector is always safely secured with it's clip connector.The problem are the wires which connects to connector's pins.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
