Hi guys,
96 850 turbo platinum edition; I had to gun it to merge into traffic last night, and immediately afterward I got a case of putt-putt and cel. Code came up as misfire on cylinder 4. Rpm's did not go above 4500, so I was a bit surprised. The plugs and wires are old, like 1999 old (I just ordered new plugs and wires 2 days ago of course). Here's the kicker: it shakes like a mother at a stoplight, but runs smooth as ever above 1000rpm. No misfire. Any suggestions? I'll do a compression test in the next day or so.
Bob
Does this sound like a burnt valve?
- Has thanked: 17 times
- Been thanked: 35 times
I don't think you would get a smooth ride at any speed if it were a burnt valve. Instead, maybe you tore through a motor mount- possibly the upper torque mount above the engine or the lower tranny to engine mount. I still am not able to explain the sudden misfire. I hope you ordered the correct bougicord wires.
- Jazzer
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
I did order Bougicord wires and Volvo plugs, as well as a Bosch distributor. I'm still getting the misfire, but it only kicks in after coming to a stop light. I'll clear the code on the highway and will be smooth sailing, but starts to shudder as I slow down. The upper torque mount is brand new oem, but the lower mounts must be shot since it sounds like a squeaky mattress!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Huh? No misfire while driving? Then it's not a burnt valve. Valves don't unburn because you are driving. I will say this, when these cars are misfiring on only 1 cylinder, they do drive pretty smooth when above 1500 RPM's. If you do have a burnt valve and decide to continue to drive the car, disconnect the fuel injector to the bad cylinder.
- Jazzer
I guess the compression test will tell the tale; once I've cleared the code while driving it will stay clear until I exit the turnpike, then the cel comes on as I slow to a stop. I'm hoping it's not a burnt valve, obviously...
- Has thanked: 311 times
- Been thanked: 817 times
That does not sound like a burnt valve.
Check all vacuum lines, and especially the intercooler hoses and connections, for leaks.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Maybe one of the intercoolerhoses got knocked loose a bit. The non metered air could cause this behaviour. Or something with the idle conrol (therefore good on the freeway, bad at idle). Good luck
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Rough running especially at idle is classic for a split or torn hose. The misfire would be unusual for a vacuum leak, you are correct about that, unless it is a big one (e.g. a split intercooler hose). The car is 20 years old, unless all the vac lines are suspect unless they have all been refreshed, I would definitely check them out carefully. TBH I like to just replace them all whenever I get a P80 car.
- Jazzer
I've got the plugs, wires, cap and rotor, and smaller vacuum hoses ready to install; just waiting for a day off to do it all! Though right now the turbo is running quite nicely, with plenty of boost (stock boost, but it's there). Would this be the case with a torn or broken intercooler hose?
- 1016 Views
Last post by wizechatmgr
- 1737 Views
Last post by Clemens
- 644 Views
Last post by E Showell
- 559 Views
Last post by dosbricks
- 1292 Views
Last post by rspi
