Timing kit questions
josefdavid
Year and Model: s70 T-5 98'
Post by josefdavid »
I'm at 240k on my 1998 S70 t5 auto
Need some help choosing which products to replace all the usual suspects
Timing belt
Both pulleys
Tensioner
Water pump
Serpentine belt
Cam seals(how many)
What can I buy as far as brands go? I understand oem is preferred but I've also read you get by with some other brands
Any help would be greatly appreciated. Links are helpful also
A link to a relevant post works too
Help me get this favorite car of mine back on the road
Thanks in advance- Josef
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Back on the road? Did the timing belt break?
Are cam seals leaking?
Aisin water pump, INA rollers, Contitech belt, Aisin tensioner (if hydraulic).
Year and Model: 2004 V70 2.5T
Been thanked: 467 times
Post by cn90 »
I summarized everything below.
- Aisin WP.
- TB Conti
- Seals: Corteco only.
DIY: 1998 Volvo S70 Timing Belt, WP, Cam Seals, SB Overhaul
https://www.matthewsvolvosite.com/forums ... hp?t=53722
splattj
Year and Model: 1999 V70 XC
Post by splattj »
cn90 wrote:I summarized everything below.
- Aisin WP.
- TB Conti
I'll second those brands. OEM Volvo is also acceptable if you have a hard time finding everything piecemeal.
josefdavid
No just a leaking water pump most likely the gasket. But I've never done these items. Bought the car at 160k now having 240 I figure better get it all since I'll be in there. If my seals aren't leaking should I still change them?
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
I used all the parts mentioned above and they looked/were exactly like the original parts,
very pleased with the results.
Also, you need a short Torx T-45 (assuming it is the same as the 850) and I found this one to
work perfectly: https://www.matthewsvolvosite.com/forums ... 47#p398047
It is a tight fit and I could not fit a torque wrench on the T-45 so just did it by hand, I did
torque everything else.
Another tip, checking/scrapping off the old water pump gasket is very difficult, someone
suggested taking the wheel off and going through the wheel well - wish I had known this
when I did the job. Luckily no leaks anyway.
Here is my thread with lots of basic questions and advice from experts on here, even with
many pictures: https://www.matthewsvolvosite.com/forums ... =1&t=74727
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
josefdavid wrote:No just a leaking water pump most likely the gasket. But I've never done these items. Bought the car at 160k now having 240 I figure better get it all since I'll be in there. If my seals aren't leaking should I still change them?
None of the parts you mentioned has been replaced since you bought the car? And it now has 240K on it?
:shock:
M1 10W-30 HM
josefdavid
If my vin ends with w2493035 what's my chassis code
Most parts say from chassis code 1266129....are these parts for me?
rspi
Post by rspi »
josefdavid wrote:If my vin ends with w2493035 what's my chassis code
Just pull the cover and look at the parts, mainly tensioner.
