Hi,
I have a 2007 s60 (2.5 turbo) the key fobs work just fine but to use the key in the drivers door does nothing.
The manual lock rotates with the key just it does not unlock door.
Anything I should know before I open up the door panel?
Thanks,
Keith
key in doorlock fails
JRL
- Year and Model: Several
- Been thanked: 16 times
It's broken!
- Has thanked: 1507 times
- Been thanked: 3824 times
Sounds like a failure in the driver door lock module. I've never dived into one if these on a P2
Looking in Alldata,it looks nasty ..rivets drilled out in doir to remove the lock module, etc. might've a candidate for body shop .
$100 part, 1 hour shop labour in the estimator
And all this talk about dreadlocks? I didn't know cars had hair let alone Rasta.....
I just suffered through this with my P80 rear latch - brass part riveted together, needs a $5 plastic bit, but replacement part $160
Ok sorry for the delay,
I popped the skin off, (the last warm day we had!)
drilled out the window guide rivet at the bottom of the door (replaced with a bolt).
turns out the rod from the door handle fell off.
Hand the new one in my hand so i used it anyway just zip tied the clip! with some extra reinforcement.
All good
Thanks folks!
All good
Thanks folks!
