Replaced seal, still leaking, time for a new drive axel?
Legofan
Year and Model: 2001 S80 T6
Post by Legofan »
01 T6 with 138k and the right(passenger) axel seal was leaking. I replaced the seal and it still leaks. Is it possible the shaft has warn out of tolerance and I need a new drive axel?
2001 S80 T6 Moondust sent to auction for scrap
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
Is the leak coming from the axle itself, ie the rubber boot on either end, or from the transmission that rhe axle pops into? I assume it's the transmission, in which case replacing the axle should not make a difference, I believe.
Legofan
Post by Legofan »
Cees Klumper wrote:Is the leak coming from the axle itself, ie the rubber boot on either end, or from the transmission that rhe axle pops into? I assume it's the transmission, in which case replacing the axle should not make a difference, I believe.
It's the transmission side, I used a cheap aftermarket seal that was $10. I'm guessing I should use a volvo seal. Replacing it is not a big deal, I just want it to stop leaking. It's not terrible, but I can smell it after a drive somewhere
The axel isn't damaged but you can see where the seal has rubbed for 137k miles. I guess I'll change the seal again.
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
When you put the new seal in leave it about a 1mm from seating in the housing so the seal lip rides on a different part of the axle shaft that hasn`t been worn by the old seal
Legofan
Post by Legofan »
ThommyKent wrote:When you put the new seal in leave it about a 1mm from seating in the housing so the seal lip rides on a different part of the axle shaft that hasn`t been worn by the old seal
Good tip, I'll try that. Thanks.
