finally.. it start up with no hesitation or whatever...
bullet79
Year and Model: 1997 940GLE
Post by bullet79 »
at first no start.. no spark..rewired the radio interference relay connector.. change RPM sensor.. viola..!!!
but the seatbelt warning noise is killing me..
and the front brakes vibrate quite hard.. is it the ABS? or the brake itself?
no start at the first place
idling like a good kitten..
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
Re: brakes
If you feel the vibration in the steering wheel when you are not applying the brakes, then the wheels are either unbalanced or out of line (needs an alignment)
If you feel the vibration in the car (seat of your pants) when you press the brakes, then the brake rotors are warped and need to be machined or replaced.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
bullet79
Post by bullet79 »
yep.. that exactly what the foreman say.. new pads too
