reuse PCV parts?
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
About six years ago, all the the PCV parts were professionally replaced, but I have excess pressure again, with all the symptoms of a clogged PCV system. So under the manifold I go. I plan to put in the larger 5/8" hose, but can I reuse any of the existing parts? I'm not being cheap, but No need to spend is there is no need for it....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
I reuse the hoses but not the container. Be sure to get a OIL rated hose, not a heater core hoes nor silicone hose.
Get 3 ft and ship it to your house.
http://www.ebay.com/itm/291442927889?_t ... EBIDX%3AIT
From two different cars.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
azureblue
Thanks. Local auto parts store has 5/8 fuel / hydraulic line. I hope the can doesn't look that bad, but I will replace it, then.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Been thanked: 504 times
If the container (oil trap) is 6 years old, I'd re-use it.
Just clean it first to be sure no clog.
The 5/8-inch hose you mentioned should be good.
I did that mod 3 years ago, so far so good, this is the thread on the 5/8-inch hose mod.
PS: I used regular heater hose (not fuel-oil rated hose), so far so good, zero issues 3 years later:
DIY: 1998 Volvo S70 GLT PCV Mod: no more smoking dipstick!
https://www.matthewsvolvosite.com/forums ... =1&t=53448
azureblue
In the meantime, what can I do to relieve the crankcase pressure? i read that about a modded filler cap but couldn't find anything about how to mod it..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Before diving in, remove the intake pipe at the turbo and see if the metal tube the vac line going to the box is clogged. Also pull on the large & small rigid lines as they tend to crack inside the foam tube, meaning no vacuum makes it to "the box". Both times mine have cracked right below the distributer.
Back out the oil dipstick to relieve the pressure.
Do you use 100% synthetic oil?
M1 10W-30 HM
M1 10W-30 HM
azureblue
Thanks - I'll check those hoses.
I pulled out the dipstick and slid a 5/8" hose over the dipstick tube that vents under the car...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
No, I don't use synthetic. It's a near 250K car. I use 10/40.
So I need just the intake manifold gasket and a new hose?
"Before diving in, remove the intake pipe at the turbo and see if the metal tube the vac line going to the box is clogged. Also pull on the large & small rigid lines as they tend to crack inside the foam tube, meaning no vacuum makes it to "the box". Both times mine have cracked right below the distributor. "
I'm going to look for a picture of that. I was just in there to replace the rubber coolant pipe.......
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 1795 Views
- 32 Replies
- 5519 Views
Last post by PeteB
- 2056 Views
Last post by EngineeringBloke
- 593 Views
Last post by valvolvo70
- 2905 Views
Last post by blandis
