What to check/replace at 250k miles?
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
This afternoon, I found that my 2000 V70's headlight dimming rocker switch was loose because the plastic holding its metal clips had broken. That's the kind of thing that only happens to a 16-year-old car with 250k miles.
What other uncommon problems should my mechanic I be looking for at this age and mileage? What parts should I proactively replace?
At 160k miles, pressure built up and a coolant hose blew off, causing the engine to overheat and warp. I had the engine replaced with a 100k mile used one (thanks Eerie Volvo). Now that engine is coming up on 200k miles. There appears to be oil seeping out around the oil fill cap.
I love my 2000 V70 with 5-speed manual and want to keep rolling to 300k miles and beyond. I take good care of it with dealer service and OEM parts. It's running great right now, and I want to ensure I don't have a sudden problem which wrecks the car. Thanks for your replies and all the posts which have helped me keep the car running for the past 14 years and 200k miles that I've owned it.
FireFox31
Has thanked: 1610 times
Been thanked: 4065 times
At 250k you should have renewed:
The entire cooling group including water pump
Be on the Volvo timing belt schedule ( halfway through your third timing belt)
New PCV system including block cleaning
Valve stem seals if there is any oil usage on overrun
You, the driver, keeping speeds at 65 or under and following distances of 3 seconds
Otherwise enjoying rowing the great M56 transmission and sending Matt stick shift videos!
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
My current "experiment" car is a 2000 S70 with 248K miles, manual transmission. Here's what I replaced:
- timing belt (it had never been done)
- timing belt tensioner and idler pulley
- water pump, thermostat, and resulting coolant flush
- serpentine belt
- the manual transmission oil... wow was it nasty coming out!
- headlights (the old ones were very dim due to cracked reflectors)
- the alternator's brush/regulator pack (only 6mm remaining)
- rear shocks - the old (original) ones, when compressed, stayed there
- went to each ground point, removed the ground wire, sanded off any corrosion on both the cable connector and the mount point, reinstalled and coated with Vaseline.
The previous owner hadn't done much maintenance except the occasional oil change and brake replacement, so I had a lot to do.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I bough my S70 at 254k, it needed fuel pump, heatercore, clutch, engine, motor mounts, etc
https://www.matthewsvolvosite.com/forums ... hp?t=76509
85 GLH, 367 whp
00 Insight, 72 mpg
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
I'd look at the stage 0 list and work my way through that... That's what I have done on my 98 V70 w/ 130k miles now...
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
Dont forget to oil the locks and latches. If your door pops when you open it, tighten the 10mm bolts on the thin elbow that stops the door from swinging all the way open.
Elmers glue on the edges of your headliner if its starting to fall. Be sure to brush off the dirt first.
Heater core is best to do before it leaks. Spark plug wires and coil, etc....
I replaced all of my bulbs, the interior with led to save power if I left the lights on. For the exterior, I only used led for non-flashing lights due to excessive complications.
If you do your suspension, I would try to do the entire thing, front and back at once. (I used a drop in suspension and the cheapest parts on ebay, costed less than $500) Replace the tires last and your tires will last.
I replaced my coolant reservior tank and cap when I did my cooling system, just because I have seen many painstaking stories in which it is the culprit.
Same for the accordion shaped tube going to the throttle body from air filter housing, the old plastic can sometimes crack when changing the air filter.
I washed my seat belt.... 5 times.
The interior fan blower moter and resistor should be done at the same time, as well the cabin air filter.
Of course, redo the ground wires as stated above, I used 6 or 8 gauge wire.
The mass air flow sensor is also often overlooked and can make a hell of a difference. I just got a used one and my car runs alot smoother.
I bled my power steering fluid too, easy to do, made my steering non jerky. Same for the brakes...
Everything else is covered in the stage 0 checklist im pretty sure.
Good luck! I hope you make well through 300k
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Replace the gasket around your oil filler cap every other oil change, if not every change, and you're likely to eliminate that leak.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Covert
Year and Model: 1997 850
Post by Covert »
Can anyone link me to the satge 0 list please ?
Many thanks
charleskennedy23
Charles Kennedy
Covert
Post by Covert »
Thanks very much
