Give it to me straight: any chance I could jury-rig with a Timesert (or similar) and a hope and dream for a couple of weeks, or do I need to definitely need to replace the pan before I have any shot at driving?
1998 V70 - Is My Drain Plug Hole Salvageable or Is it Time for a New Oil Pan?
Hi all, here's a shot of my 1998 V70 GLT 2.4L oil pan.
No, and the tire's not actually totalky flat, I just haven't been able to refill it with air since I had to have it towed home. There's a minor crack in the wheel from when I got hit by an uninsured driver (also a bunch of other body damage) so until I replace that, I've been able to keep the new tire going with air. What's baffling is there was no hit when the oil suddenly drained, just a bad bump in the road, but it's been pretty low to the ground since the accident.
Sucks to hear the truth but I'm glad for a response, thanks!
- Been thanked: 504 times
The oil pan is kaput, the part where the threads normally sit is ripped off badly.
Oil pan is cheap on ebay, about $100 or so.
Or junk yard...
Make sure you use the Volvo sealant during installation.
PS: My theory is whoever did your oil change over-tightened it like a gorilla, causing microscopic crack (metal fatigue) and boom...
You are lucky the motor didn't seize.
Or junk yard...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Is it sure it wasn't just a loosened bolt? As above, if the engine was running even for 1 min without oil, even without an oil light, I'd check the rod bearings
- Has thanked: 2199 times
The bolt hole is broken clean off. Either been hit or hit something, or over-tightened. whatever, new oil pan needed assuming the engine hasn't been oil starved and run the bearings.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Does anyone else remember those ads for synthetic oil that used to claim synthetic was soooooooo much better than conventional oil that you could run it in your car even if you drained the oil? I know you should NEVER run a car without oil. But does a high quality synthetic protect an engine for a few more minutes than conventional oil during a catastrophic failure such as this?? I hate to admit it, but I think I swear by synthetic because I imagine it protects better, more, than conventional oil. Am I totally off here?oragex wrote:Is it sure it wasn't just a loosened bolt? As above, if the engine was running even for 1 min without oil, even without an oil light, I'd check the rod bearings
Retired:
2015 Volvo S60, T5, 85K
Jaguar xjs
- Year and Model: 1996 850 turbo
Looks to me like the pan has had multiple hits. The aluminum is rolled back and there are hairs and threads of metal pointed up. Need a new pan no doubt. Hopefully no spun or oil starved bearings.
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
Just search youtube and saw this funny video, 2nd attempt to kill a Red Block engine (B230 engine used in the Volvo 240).
This engine had 230K on the odometer, painful to watch (LOL) but you can see the effect of no oil...
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
At idle you can run the engine without oil for a long time with no damage. Unless you were racing the engine when it suddenly lost oil everything should be fine.
- 12 Replies
- 982 Views
Last post by 02V70
- 1200 Views
Last post by MoVolvos
- 5384 Views
- 1412 Views
Last post by Navy
- 594 Views
Last post by RickHaleParker
