Need help fixing Stripped Motor Mount Bolt Threads on Engine Block
tidyphone
Year and Model: 2005 Volvo S40 T5
Post by tidyphone »
Hi Guys. I'm in a bit of a pickle and I was hoping someone could give me some advice on what to do.
I have a 2005 Volvo S40 T5 Automatic AWD and my passenger side motor mount was shot. I decided to change it and upon unscrewing the two bolts that attach the mount to the engine block, I was presented with two destroyed bolt threads. The bolt threads are on the engine block itself. It appears that the last person who changed the motor mount destroyed the threads and used some liquid thread to patch up the broken threads.
Unfortunately, I didn't realize that they were using liquid thread and when I re-tightened the screws, I ended up damaging both threads completely. Liquid thread is no longer going to help me. As of now, one of the bolts is able to withstand about 30 pounds of torque before it fails, and the other one can only withstand about 7 pounds.
I'm trying to figure out what would be the best way to fix this. While researching online, I got a bunch of different opinions. Some people said to re-tap the thread and use a helicoil, others said to re-tap the threads and use a bigger bolt.
What do you guys think would be the best way to fix this? Any suggestions are warmly welcomed!
Here are the pictures http://imgur.com/a/duIUZ. (I forgot to take pictures and measurements while the bolts were out. I'll try to take more pictures when I get home.)
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
I would not hesitate to use a helicoil.
BUT, only if you can be sure that you can get a clean tap and insert in there.
I would not even try if I couldn't get a perpendicular hole / tap / insert installation.
'84 Prelude
'06 MPV
'13 Ford Focus SE
pmondrian
Year and Model: S40, 2004.5, 2011
Post by pmondrian »
Hi, I'm in the same situation as you were. Were you able to fix your situation? If so, how? Thank you in advance for your help!
