Mysterious driving sound
rob6523
Year and Model: 2007 V70 2.5T
Post by rob6523 »
I have a V70 2.5T automatic MY2007.
Driving at a speed from 10 - 80 miles a knocking sound appears that sounds like a drive shaft problem, the left side drive shaft has been replaced, as wel as the left front wheel bearing are new, and the dealer has suggested to renew the automatic transmissionoil but the sound remains.
Anyone knows where to look or someone who has had the same "problem" ???
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Although it may be time to replace the trans fluid, I struggle to correlate dirty fluid with a "knocking" noise.
Are there any conditions under which the noise increases or decreases - like when you step on throttle or let off the throttle? Can you "feel" the knocking in the steering wheel or your feet? Or do you just "hear" it? What happens if you accelerate hard from a stand-still with the steering wheel cranked far to the left or right?
difflock54
Year and Model: V40 Nordic 2002
Been thanked: 2 times
Post by difflock54 »
May be worn control arm bushes, ball joint or strut mount?
rob6523
Post by rob6523 »
Thank you for your suggestion chrism!
A Volvo specialist said that it is a bad wheel bearing on the right side so I'll replace that after the part comes in.
Strange how the hearing of a sound can be off (hearing the sound on the drivers side where it actually is caused on the right side!)
Has thanked: 1610 times
Been thanked: 4068 times
If it's a wheel bearing noise it will change when you steer left and right. Bearings usually growl or whir rather than knock.
You can also jack up all four wheels and run car to confirm
