Coolant temp gauge 850t.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
Thinking about installing a real engine temp gauge in my car but can't find much that details how-why that might be useful. Just had the head done (burnt valve and bad seals) and am paranoid about over heating this car. Ideas?
AKJeeper
Year and Model: 1996 850 Turbo Wagon
Has thanked: 7 times
Post by AKJeeper »
I can tell you that after having a ScanGauge in my '96 to give me the temp straight from the coolant sensor: the factory temperature gauge stays right in the middle at any "normal" temperature. I forget the exact range for 'middle', but it's something like 130*F-220*F. Not exactly usable in my opinion.
I was playing with the idea of installing boost, oil pressure and engine temperature gauges, too. My gripe was that I couldn't find any 850-specific gauge pods that would integrate nicely with the dash. I got the ScanGauge for the time being and used velcro on the ash tray lid to provide coolant temp information. Wish I could figure out a way for it to display boost.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
A nice place to install gauges in any car are the glove box or the a pillar (if you have a spare a pillar panel and like to work with styrene) you can make that look really nice and as if it was supposed to be there.
I think someone on here fabricated a fantastic boost gauge in the a pillar.
1996 855 R,
2010 V70 D5,
rguzz
Post by rguzz »
What are the mechanics involved in installing a temp gauge? It does appear the Scan Gauge essentially requires no installation other than a place to plant it. Does it provide accurate engine temps? I know there is a video (RSPI) around with some details.
beigg
Year and Model: 850 97
Post by beigg »
Oil temp, Boost, Wideband are the three I use in the triple pod. thought about omitting the wideband in favor for a coolant temp.
ugh smh 850 Turbo fridge
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
rguzz
Post by rguzz »
How did you hook up the temp gauge?
AKJeeper
Post by AKJeeper »
Aftermarket temp gauges usually need a few connections: dash illumination, temperature sender/sensor, and ignition power/ground. Some mechanical gauges utilize a sealed tube that will need to run into the engine compartment and tap into the water jacket (same spot you'd install a temp sensor for electronic gauges).
Mechanical gauges require less electrical connections (usually just dash illumination and ground).
rguzz
Post by rguzz »
BTW, does you ScanGauge not display boost?
AKJeeper
Post by AKJeeper »
I have not been able to figure out how to get boost readings from my '96 with the Scan Gauge. :(
